sky hd tv guide
Hi Guys
When using my beo4 sometimes will scroll through choose the programme i want press go go to select and will default to planner  will happen two or three times then will select correctly. I have changed the batteries just in case.
When using the beo5 there are no problems  whatsoeve,r so must be the beo4 signal
Anyone any ideas what causes this  weird situation
your help appreciated
malcolm welborn
GO GO is select, as you rightly point out.
GO and leaving alone for about 5 seconds will cause 'play' to be pressed.  This will jump you into the Planner to choose a program to play.
Therefore the obvious issue is it's only registering one of the GO's.  Maybe if the batteries aren't the issue, the button's wearing out?
thanks will try beo 4 is only 6 mths old
I get that with Beo 4 and Beo 5, drives me nuts!!
i know what you mean, but be interesting to know why
beo5 no problems why problems with beo4 ( beo4 is new and put new batteries in)
Any boffins out there know,Maybe Keith
malcolm
any boffins out there know Keith any ideas
The logical suggestion would be to test another Beo4.
If the problem still exists, then something's up with the TV (or the way you're operating the remote, but it's hard to see how you could do it incorrectly!).  If the problem doesn't exist, then your Beo4 is faulty.
yes take your point, but did not have a problem when i had sky standard . only arisen since moving to sky hd,
understand sky had problems with new format sky tv guide, could that  be the cause
malcolm
If it's jumping to the planner, then the TV is sending the 'play' command not the 'select' command.  I don't think the box could have anything to do with it.  Play is Go (long hold) or Go + 2 sec timeout delay - so somehow, this is what the TV is registering.
If it's intermittent, it really does point to the remote rather than a fault with the PUC programming or other issue
Sky standard didn't have a play command, so per the command list the two separate commands for 'select' and 'play' for Plus/HD both carried out the 'select' function on Sky Digital.
http://beotech.beoworld.org/skydigital.htm
hi many thanks,  my wife will have to learn to use the beo 5 lol
only got the beo4 with the tv for her
did go twice slowly did not jump
malcolm
I had a friend who kept doing this with my Sky box linked to an avant - turned out he was holding down go for too long - needs to be two presses quite quickly and pointing at the TV. One long press of go causes the last thing played to resume or goto planner if it has been deleted.
