Similar IR-codes for the Popcorn Hour ?
Hi, I posted a thread a while ago concerning my mediaplayer Popcorn Hour that I would like to control with my B&O-remote. The Popcorn is not yet added to the PUC-list but I found some interesting information regarding which IR-codes the Popcorn uses. If you follow the link, does someone have a clue if I can use some other device from the PUC-list that uses the same codes as the Popcorn ??
If you use Beo5, maybe Keith can make it work directley from Beo5
I know Beo5 can handle NEC
I have a Beo5 so it would be really nice. Is it possible that you can help me Keith ?
Best regards
Hans
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 SEEKlink032211242013000000TITLElink032211096159000000UPlink032211152103000000ZOOM
How did you guys get on with this. Please let me know if you got anywhere.
Thanks,
Ash.
A Beo5 XML template for the Popcorn Hour A100/A110 is now available for download HERE
Keith,
You're a legend!! Thanks very much for your efforts!!
Ash.
Cool, just a quick question, would it need to have a line of sight for the IR or could you se the STB-C on the TV to send the IR signal?
Many thanks Keith !!! Really impressed with your skills.
Best regards
Hans
Just wanted to tell that I downloaded yesterday and everything works like a dream. Thanks again Keith !
Best regards
Hans
