Shipping a Beogram 5500 safely
I am currently selling and will soon be shipping a Beogram 5500 to its new owner.  It will be shipped within the USA by FedEx.  I have located the tansport screws on the bottom and they seem to lock the platter down.  However, do I still need to remove the platter and platter base for shipping?  Or, can I just put packing material between the lid and platter to hold it down?  Any other measures to consider?
I will also be shipping a Beocenter 9000 and have installed the two tansport screws on the bottom for the CD drive.  Any other measure on this one as well?  I will be double boxing both units with professional packing materials.  Thanks for your guidence.
The Beogram 5500 platter would have to be taken off, and some protection against arm rolling should be inserted at the arm slot in the back. Ship the stylus seperately in a safe box.
You should also take some precautions when shipping the Beocenter 9000. The lower glass panel is known to loosen under transit, as it's just attached with double-sided tape. It it loosens, it will scratch the surface and self-destruct in small fragments of glass. See this video as a scenario of the damage done when shipping one of these wrong:
You should also take some precautions when shipping the Beocenter 9000. The lower glass panel is known to loosen under transit, as it's just attached with double-sided tape. It it loosens, it will scratch the surface and self-destruct in small fragments of glass. See this video as a scenario of the damage done when shipping one of these wrong: link
Ouch, that hurts to look at it.  So, if I float the unit inside a double box with foam around the glass panel that should do it best I can, right?  Thanks for the advise.
Seen this?
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
kallasr wrote:
Seen this?
Ralf
Good advice to follow.  Many thanks.
Just want to clarify about taking the platter off.  There is the top platter, then there is a black spacer beneath it and then, the main platter base that has the gear attached and the belt around it.  Should these come off for shipment also and belt removed as well?  In addition when the belt is taken off the drive spindle it is not tight againist the platter base but rather it falls off.  Is this correct or is this an indication of a worn belt.  (the turntable does play normally and all functions work properly).
Thanks again for your guidance.  I want the new owner to receive this turntable in good shape.
