Shadow mark on screen
Is it under warranty? If so, back to the dealer it goes!
If it had been a CRT, i'd have said it's too near to a speaker - but LCD?? I'm sure someone on here can help advise what the fault may be. Welcome to BeoWorld !!
Lee
Thank you!
Well it does look exactly like the shadow you would get on a CRT near a speaker...excpet its not CRT and not near a speaker!!! Its not under warranty sadly. It only appears after about an hour, so I wondered if it was some sort of strange software problem, rather than a problem with the backlight.
I think I know this is bad, I was just hoping someone had information otherwise!
P
Hi, did you find out what it was? I only ask as I also have the problem on a BV6-26 on the right
Regards Douglas C
