Setting up a B&O system
@Jens,
did your B&O dealer never tell you about integrating or connecting the Core with the BV Avant?
That is what is called NetworkLink.
If you do that, you will have new sources in the source list of the tv - the socalled linked sources.
You can start these from there and the volume is controlled via the Avant/the BROne.
You can read about this in the User Guide of the Avant.
Note: there are some further steps to make for the Core using the Bang & Olufsen app.
Unless I got the history wrong, you have bought the majority of your kit from the after market. If so, there does come a time when it might benefit you to hire a B&O expert to go through your entire system and hold her/him accountable for results. Or maybe not.
Millemissen wrote:
I can’t edit either, unfortunately ☹️
Unless it is already the case, why don’t you use the BeoWorld app on your iPad ? Editing, quoting and inserting images are much more user friendly than in a compatible browser.
"My dealer gave me an IR receiver (round one with a few buttons) that I plugged into the Core, witch was supposed to give me remote control. This I never got to work.. It only gave me the possibility to turn on/off the speakers."
The Core need to be a special version that can handle the IR commands fully. Have your dealer confirm if the Core is the correct version.
Sorry, no way!
I did try that long time ago, but quickly ditched it.
Might be a good solution on an iPhone - I prefer the browser version on my iPad.....
....even if I can’t edit (it’s not that big a problem).
N.B. Quoting and inserting pictures is no big deal on the iPad/Safari - I do that all the time.
I agree there.
At first someone with that many options/devices must find out, what he wants to do, how he prefers accessing his/the music, radio etc etc.
Then someone ‘in knowing’ can give the right advices.
Not that the op can’t do that on your own, but it will probably be much trial and error.
I have seen this clip on you tube from B&O fan a bit long- winded conjure a hifi/ tv to work with wisa hope this helps.
Nice video from Ethan - but does not help much to the subject of the thread.
