Set IP for BeoMaster5?
I have my BeoMaster5 set to a fixed IP address, but I don't remember how I did it. I'd like to change it. Does this require going into the service menu?
A fixed IP is defined in the internet router not in the BeoMaster5.
I have my BeoMaster5 set to a fixed IP address, but I don’t remember how I did it. I’d like to change it. Does this require going into the service menu?Haven't tried it myself, but wold think so. On the Windows desktop there should be an icon labeled network connections. If you go to that you should be able to see something probably called local area connection. Right click on that and select properties. Now you should see an option to select TCP/IP, and in that you should be able to change the IP adress Hope this leads you the right way althought only based on my knowledge about Windows XP, and not doing it on a BS5
