Service Kit for BeoCom 6000?
I can't get it to list the sw version. if I type 9#9#9* nothing happens (other than the display show what I typed and it will try to call that strange number). I have also tried to do it from the menu, but still can't get it to show the sw versions. What do I do wrong?
Ken
Well I will check too the sw version of my BC6000 base.
I will need to replace the speaker as this one is HS.
BTW, I have a technical question :
- Is there two different speakers that manage the sounds linked with the ring-tones and the "bips" made when moving the wheel ?
 In fact I can hear the bip, not the ring-tones.
Your answer will help me to know precisely which spare parts to buy (not forgeting the cosmetic aspect of the refurbishment of the phone).
Thanks for your input.
Guy
Sorry ken that the code for the mrk2 Yours is a mrk1 type 9#9#9*dot button 7 then move the wheel to say bs sw version
No its only one speaker.But you can't buy it on its own it attached to the back cover so you need to order a Top handset i which ever colour you have.Tony
