Service counters on BV11 ?
A wee question.
Is there a way to access counters on the BV11 like on all the B & O tv's since twenty years before it ?
Like Video days, on/off times...
Thanks,
Gregory
Thanks, will try that. Must be the same on Bv11.
mauszwerg wrote:
Don't know wether it is the same with a BV 11 but on a Beoplay V1 you can find Reporting in the customer service menu. Load the report to a USB stick and unpack the files with a computer. the service counter is in tmp > reporting > flash > calibration data.
Ralf
Where can I find the customer service menu on a Beoplay V1?
Menu + settings + red and go in the remote.
Ralf
It worked indeed, many thanks.
The report is maybe a hundred of lines and one line is "service counters".
You have counters for hdmi 1 to 6, youtube, spotify... in minutes.
For example, I have 164 minutes of spotify or 5000 minutes of hdmi 1 (dtv) in one month and a half of use.
Gregory
i wanted to save the tuner settings to a usb stick.
but it doesn't work.
the report i can save to the stick.
same here. Tuner settings cannot be saved to the Thumb Drive...
same here
ralf
