Serial # on Beocenter 2
Hi!
Where can I find serial number on Beocenter 2. Need a new pin code
br
If it's a PIN you need, the Serial Number required is on the black socket box.  It'll be near the myriad of connections on the inside as opposed to the outer casing.
Lee
thanks!
