Serial number number when sticker is gone?
Hi BeoWorlders
Is there a way to tell a serial number on a B&O product when the label is gone/torn off? Maybe it is possible to track the serial number from a partnumber?
Best regards,
Frederik
Serial number is repeated on 3 differente place of each Beolab. For ex in Beolab you can found near connection, under the pot cover of lens and inside on lower section of case. In beolab 6000 near connection or upper the first woofer (depend of serial),inside the case and the rear of little plsatic cover of ampli.
What beolab do you have?
It is a set of BeoLab 9
I have taken the back part off now. I cannot locate it inside the case or on the PCB 😕 Could you point to where specific I should look?
Beolab 3 has it inside the Accoustic lens, perhaps the BL9 does too?
