Serene - DECT communication
Hi everybody,
Hope everyone has a good weekend.
I'm one of those unfortunate people who bought Serene from Samsung (desktop charger without DECT module).
Today I've got new desctop charger (Part No 8080013) from my local B&O shop.
As far as I know I should get an additional menu on Serene for registration to my Beoline base (p.n. 1113068) when I connect Serene to that new desctop charger - I haven't got. There is nothing about it in desctop charger manual.
 Could anyone suggest what might be wrong?
Thanks a lot,
Sasha
I guess you need a software update.
When it is on it's dock, press
OK
Settings
Does option number 9 say "Docking Station"?
Just out of curiosity, Does it say Bang and Olufsen on the hinge, or just Samsung?
No, there is no option "Docking Station" in Settings when Serene is on the new dock.
Serene has both Bang and Olufsen and Samsung on the hinge.
According to FAQ about Serene on the main B&O website there is no difference in Serene sold by B&O and Samsung.
The difference in only in desktop charger.
Regards,
Sasha
In which case, I would follow Peter's recommendation and take both your Serene and your new docking station into your dealer for a SW update.
Please keep us informed.
Andy T.
Yesterday I was working at my local B&O shop and our boss told me that if you buy a Serene from Samsung B&O does not condsider it to be a Serene at all.
 Plus they will charge you (in Belgium) 25 euros
OK guys, thank a lot for an advise.
I'll ask my local dealer for Serene software update and keep you informed.
Regards,
Sasha
I've asked my local B&O dealer about SW update for my Serene (bought from Samsung) and he told me that it is not upgradeable by B&O at all.
Is it correct? If yes - Is it due to a technical reasons (connectors, protocols, drivers incompatibility)?
Or is it just a administrative barrier to separate responsibility between 2 sell chains?
To be honest I don't believe that there are 2 different SW upgrade procedures for Serenes.
I'm a programmer for 28 years and I can't find a reason for developers to implement 2 different incompatible SW for the same product.
BTW, does anybody know how to check SW version on Serene?
Best regards,
Sasha
To see the software, press *#1234#
To see the firmware, press *#1111#
Maybe is on contrary, i am not sure.
Thank you Quim,
My Serene returns:
*#1234# - E910XXEL3
*#1111# - F-REV1.0C
What about your Serene?
Regards,
Sasha
