Sending sound from BV Horizon to Moment/BeoPlay A9
😎 coolSomehow I cannot upload a photo but I can confirm the Horizon to show up as link source. Joining a TV program does not produce sound out of sync.
wrong answer - deleted post
I just don't understand why this isn't working for me. I'll try again when I get the new BSM. Currently the Horizon is connected to the Beolab's. Should I just then remove the speakers from the TV set-up (is that complicated)? Set up the speakers for the Moment and hope the TV will appear on the link page?
I must say I've had horrible experience with my set-up. Noting works. Never. This is now the 3rd moment I'll be getting (over the course of 2 years) because my previous ones just drove me mad with all sorts of problems.
The tech guys mentioned that maybe it could be my router, but I replaced my old router as well 9 months ago (thinking that maybe the router was the problem) and bought ASUS RT-AC5400, Tri-band Gigabit Router. So unless I need to preset the router somehow to work with all the B&O set-up, I don't think my router or internet connection is the problem.
What basically happens is that like with the Horizon not appearing on the link page, my Beoplay A9 sometimes disappears or I cannot connect to it in the Bang Olufsen App. BSM plays no music randomly and if I manage everything to work, if I'm lets say playing music on the BSM and join the Beoplay A9, then the Beoplay A9 would drop the connection after like an hour or two. This has been going on like this for over two years - and is absolutely driving me nuts to say the least.
Yesterday I was trying to play music on my Beoplay A9 but for some reason I could not. It always connected to the TV (and music came from the TV and no music from the A9), then I removed the link to the Beoplay A9 on the TV but still nothing... Any idea what I need to do?
So basically I've spent thousands of euros on products that never work. My dealer seriously thought I was crazy because I was always complaining. Then the tech guys came to set up the TV and instead of staying just a couple of hours it took them 7 hours (because also for them nothing worked)!! and in the end they took the BSM with them back - because also then NOTHING worked like it should. I think I'm cursed.
Thank you Fansastic,
I'll do that!
just to be sure, should the DHCP be switched off or on? Any other settings on my routers that you/others can think of that I need to make sure are in a certain way?
Hope this helps! Routers is not my thing, I have all apple airports throughout the house, one is set as DHCP and the rest is in slave mode. My Moment worked with both DCHP on and off but I think it should be switched off. My Moment is the only device on WiFi and that is not perfect. Sometimes I have to reboot the Moment because Multiroom is delayed. After reboot everything works fine again.No other advise for your router I’m afraid. Mainly try to setup all things wired, when that works perfect you can introduce WiFi connections between your products (if needed)Good luck and hope you will find your joy in short time!BRSergeThank you Fansastic, I'll do that! just to be sure, should the DHCP be switched off or on? Any other settings on my routers that you/others can think of that I need to make sure are in a certain way?
To be honest I don't wan't to listen to music on the TV. I want to be able to listen to the sound from the TV (film etc) on my BeoPlay A9 and BSM.
