Semi Solved: Beoplay A9 Mark 3 - Inputs Delay: Bluetooth & Line in
poodleboy wrote:
Line in audio delay without video processing in the loop does not make sense unless the B&O products have compatibility issues outside it's own ecosystem. In case, the documentation should state that or prepare people for more unpleasant surprise. Or did I miss something?
Yes, probably: The reason for the delay is twofold: (1) Analog-to-Digital conversion happens in real time with a very slight latency, but if you also have to compress the audio for retransmission to multiple recipients over a (potentially uneven transmission rate) network, that takes longer because you have to scan over part of the stream to compress; plus (2) Each generation of wireless speaker will have its own delay to buffer before starting to play, so the source speaker must delay its own output until it can be certain that the slowest of its destination speakers will be able to play in sync.
The Sonos systems have the same problem, and the same setting in their app to override multi-room transmission in favor of instant local-zone playback.  You can imagine that a similar problem is at the root of the Roon multi-zone caveats: RAAT implementations can all be synced up, Chromecast zones can all play in sync, as can all AirPlay zones, but not any of them cross-protocol at the same time.  You are right, the documentation should state that.  Roon are explicit about this incompatibility.  But B&O manuals have always been a travesty of icons & vagueness, so there is no reason to expect them to start now -- especially for a cross-brand experience that they have traditionally never wanted to encourage, much less support.
Makes me occasionally pine for the analog multi-room network: MCL was so straightforward: each zone had its own volume & mute, but the audio was at "electron speed"!
Thanks for the extended feedback. Extremely informative and a pleasure to read; line in without delay works fine.
The reason I cannot completely mark this as solved is due to the fact that Bluetooth is still terribly lagging in terms of a delay.
What's shocking is that my 7 year old Bluetooth speaker and Bluetooth gateway exhibit almost no lag and I did not expect this of a 2018 / 2019 state of the art speaker. Has anyone reached out to B&O to resolve this Bluetooth lag?
@trackbeo Thanks for the very informative response.
Probably not relevant for your right now but for future people,
I've had the same issue with the Beoplay M5, had a 1 second delay when using Bluetooth to play video even after I disabled delay in the settings.
What fixed the issue for me was going to (in the B& app) to Settings -> Beolink -> Sound Syncronization and there I found out that for some reason the "Network delay" was set to 1000 ms. Go figure why they did it on default but I set it to 0 and  it fixed it for me.
Hope this helps someone.
