selecting another PUC
Can the Beo5 change (toggle) the setup of a PUC on my BC 6-26 from AppleTV to Sony BDP after I pressed the configured buttons AppleTV or Sony BDP?
This is because I have only one IR-input available and therefore I use an jack-splitter. Both are hidden behind (closed) doors!
Both PUC's are available in the Beocenter 6-26.
Thanks,
Pim
Pim,
I think this is not possible. To do that you have to change the setup of your connections. Maybe someone else have an idea (a huge macro for the BEO5)?
Piet
