What should i be looking for when i buy a second hand Serene ( not from a dealer ). what are the pitfalls ?
second hand Serene
As far as i'm aware, the Serene is SIM free and can work in any country. Isn't it Tri or Quad band or something?
Lee
Check the call log, > the talk time the previous owner had put on. I just got my second hand and the previous owner didn't reset his call log (I hope) and it had 9hrs outgoing and 5hrs incoming. I found out it was brought in last June cuz it had the warranty sticker on the battery. And apparently, I found out the pictures naming was save in sequence (SP_A0001...0002 so on), so you can find out how many pictures it took by taking a pic and see what the number is. < I haven't found out where to reset that though.
Davidson
Any other thing we should be aware of when buying a used one?
Is there a way to check the serial, to see if it was stolen or something like that. And can B&O supply a new battery - for how much?
What is the latest software number and how do you check it on the phone? And has anyone figured out how to reset it - delete absolutely everything on the phone? I got an offer, but I'm very reluctant on buying it... I had a bad experience once and I want to be 100% positive.
Thanks.
PS. what is the safest way to transfer the money, if the seller doesn't have PayPal? So you can get you money back if it turns out to be a scam?
the lastes software is
despens on there youre from...
but it all end on FI1
to show sw press *#1234# on the phone
Lee
If it is not updated, can't I just have it updated myself?
My phone has version E910-XX-FA2. Does anyone know what kind of problems are resolved in later versions.
/Peter
