Latest update:
The repair boy provided to replace ALL the capacitors in PCB32, with other ones, new and high-quality, specific for audio.
The resullt is that BS9000, once reconnected via Master Link with Beosound 5 and Beovision 7, responds to commands correctly, but the volume of the sound of CD and RADIO is too low (to listen a CD or RADIO, I have to go to the max. of the volume).
The volume from the headphones plug is correct; the same with N.RADIO and N.MUSIC (whose signal come from BS5).
What could it be the problem, now?
B&O fan since adolescence. I have a multi room audio-video system with Master Link connection. In 2016 integrated the system with Beosound 5. I'm satisfied 'cause I use it for hours everyday, but sometimes any device need reparation.
