Can anyone recommend a product or solution to protect the screen on the Beo5?
Previous experiences with "skins" have proven to be too thick and very noticeable.
Could try the Invisibleshield from Zagg.
My Beo5 has been abused by little children and some women with long nails... and has been crashing into the ground a couple of times. The screen hasn't been scratched. B&O uses some kind of special treated glass to prevent it from scratching that easy..
IF you do want to have it covered then I would also recommend Zagg's Invisible Shield (http://www.zagg.com/)
Karel
