Scratches to Beocenter 9500 mirrored doors and centre panel
Hello there, i have seen one of these at a good price but was wondering if there is a way to remove scratches from the mirrored panels as they are heavily scratched. Or if i am able to buy new ones?  if so if anyone knows how much i would be grateful.
Thanks In Advance!
Don't think it's possible to remove scratches on these type of panels.
I think I must have some in my closet🙂
Anything's worth a try with a buffing wheel, I'd guess.
Whatever you do, they'll only get worse, and you'll end up wishing you had left the scratches alone.
I suppose parts for 9300 would be still available, but I believe they have a bit different finish.
Have I not sold you some used sets Leslie?
No, I don't think so Graham. On the other hand, I did order a set long time ago through Ebay, and maybe I bougt them from you? I was not aware that you were the owner of Beo4life. We did some exchanges though but not for panels!
I have sold several sets of second hand panels and my wife has sold a few.
I fit a new set to every Beocenter 93/9500 I sell and sometimes the old ones are just too good to throw away!
Then I'll keep mine as a spare Graham (sorry Ronnie). I think I bought them from you but that must be a while ago. They look brandnew...
