Anyway, the TV in question is my father's 32-inch Samsung (specifically an UE32ES5500 - a full-HD 'Smart TV' that was released about 10 years ago). The picture showed an annoying brightly lit triangle in each of the top and bottom right corners - also these areas got particularly warm when in use.
Login to view image
After some inconclusive YouTube investigation, several months ago I took it to pieces to investigate, and found this:
Login to view image
The picture show the right hand edge of the Light Diffuser Sheet, basically a sheet of clever perspex that distributes the light from the LED strip on the right hand edge of the screen across the full width of the screen. The corners fell out as I extracted the sheet - clearly the cracks had been reflecting the light internally and also causing the heat to build up. For info, here is the actual LED strip down the right hand edge of the panel (perspex removed):
Login to view image
After experimenting with glue, tape and even rotating the sheet through 180 degrees, I re-assembled it and stuck it in the cupboard as a 'pending repair' project.
Unable to find a supplier of the diffuser sheet, I put a 'search' on eBay for the same make and model TV but with a 'spares and repair' filter. Last weekend (some three months later) one came up on eBay just 20 mins from my house and I 'won' it for just 99p.
Here's the 'new' faulty one running with vertical fault lines as I had seen in the eBay advert.
Login to view image
So today I moved the Light Diffuser sheet from the 'new' TV to my father's and now have a fully working example - a very pleasing result:
Login to view image
I did have a quick look for the reason for the vertical lines on the eBay TV, and found two 'gungy/sticky' areas on the connection edge of the screen - these align with the location of the fault. I won't look further into this as I have got what I wanted!
Login to view image
Anyway, I hope this is of interest to Forum members despite being non-B&O. I'd now feel much more confident about investigating simple panel faults in older B&O TVs.
