Samsung TV-beolab 7.1
Hi all!
Can I conect a beolab 7.1 to optical audio-out of a Samsung tv?
Thank you!
The simplest solution to connecting Beolab speakers to a modern non-B&O tv would be something like this:
Almando box is best
Mikipidia wrote:
Almando box is best
…for one BL7.1 - I’d doubt that.
Do you know the small box from HallAudio?
Or get one of Steve’s solutions with a trigger😁
Hi
If your Samsung has headphone minijack out where volume is regulated via vol+/- on the remote (test it with some headphones) and a USB socket that turns on and off (maybe with a delay) I recommend this cable.
Used it for years for a BL 7.2 and a Sony TV. Worked perfectly and the BL 7.2 will turn on/off automatically.
Nothing against Steves cables.... But as far as I know he has no solution where a USB cable is providing the trigger voltage.
Your optical out is not volume regulated...
https://www.av-connection.dk/?PNo=AV-TRUSBDIN8
