[ Safari ] Forum functionality degraded?
Hi Everyone -- I am having some repeatable issues when using Safari.  Specifically, the "more" button results in a spinning wheel.  I'm running Safari 10.0.3 on a MacBook Air loaded with Sierra (10.12.3).
I saw some older threads about this, but they were last active in 2015.  Safe to assume it is just a long running issue?
I use Firefox for this site, Safari does not properly work with it as you could figure it
You can't edit posts either, which is madness. You have to switch to Chrome to edit!
I use it this way, and it works.
First, you have to check something somewhere in the preferences to enabled the "development" menu.
You do this only once.
Then, when you need it, you change the user agent. I choose Firefox Mac generaly. It remains like that until you close Safari.
