Its confusing how to connevt a pair stereo. So you need a cable for bl4pc ( stereo 3.5 to left and right 3.5mm cable) and if you set the volume on one speaker will it regulated simultaneously on the other speaker? Or can you connect a stereo signal at theleft speaker and connect the output from the left speaker (stereo 3.5mm-3.5mm) to the input from the right speaker. And set both on master mode ( orange). And can you set the volime on either the left or right speajer? The explanation is very confusing. I want to use it as a stereo wired setup with either stereo or usb input.
Hope you could help me..
