Right now, the single most artistic and creative TV I've seen, which I never would have expected from who makes it, is the Samsung Art. Something that in better days I would have expected out of B&O not Samsung, but it's an amazingly artistic and well thought out product.
I agree, but with a couple of qualifications. The concept of showing a white frame mount picture on the screen when not viewing TV/DVD etc can surely be applied to the likes of the BV11 with the right software updates. Samsung also do the B&O trick regarding connections. They claim/ show an invisible connection (single optical connection) but then in the small print say their invisible connection excludes the TV power cable and and any ancillary device cables. So just how do you mount this TV screen flat on the wall without having a large strategically placed junction box/power socket void behind the screen?
Graham
I think the thing that really impresses me most about the Samsung is that finally someone seems to have developed a set you can leave visible all the time, not hide, for people who really hate the idea of a visible TV set. Me? I don't care, my large Panasonic plasma, 65 inch, is kind of a focal point as I don't mind my living room being a media room/home theater at the same time. Some don't like this though. The BV11 is a focal point by nature of design. The Samsung also will shut the display down if it doesn't sense people in the room after a certain amount of time.
But you're right, cabling. I've never seen a B&O catalog or advertising photo that shows wiring, even though you know there is power and cabling required. I guess Samsung expects you to have a power outlet put on the wall behind it, I have that in the apartment I built downstairs, had it and cable outlets put in where the TV hangs. Clean installation. I guess if you put a power outlet behind the set the thin optical cable gives you the ability to put your cable box or disc player somewhere else, in a cabinet, and run a tiny almost invisible cable to the TV.
I got the name wrong, it's apparently the Samsung Frame.
