Tournedos,
You give sound capacitor advice. I have used foil types almost exclusively for recapping speakers in the past. The sole exception being once using bipolar electrolytic in parallel to the woofers in my Klipsch Chorus. I didn't think of it, the kit I used from a well known Klipsch shop that provided it for that purpose said there was no sonic benefit to justify the additional cost in that application. I took their word for it, and the result was excellent.
That being said, sonically there's no reason not to use foil cap.s for bypassing voice coils either. It boils down to two considerations:
1. Cost - In the larger ratings (as are typically seen bypassing woofer coils) bi-polars are much less expensive. If that were the only factor, I'd go with foil unless I were absolutely sure the application was to bypass of the voice coil.
2. Size - I'm not familiar with your RL60.2's or Pentas, is usable interior space available in them? Mounting large capacitors in the RL-140 is not a task I relish being able to accomplish effectively. Very tight in there. This tips the scale in favor of bi-polar electrolytics to be used in bypass applications. Now to go get the schematic and make sure......
Are you a native Finn? You're English is excellent, better than that employed by many Americans to be sure. I'm presently trying to learn Italian, which is giving me a greater appreciation of the difficulty in actually mastering a second language.
