The app is dead in that sense.
Its for setting up products, fiddling with sound profiles occasionally.
You wonder why the development has seemingly stopped over the last year, bug fixes aside?
As yes, as you suggest the music listing experience is not first class using the remote / app, from browsing sense. But from a starting / stopping / skipping / joining viewpoint, the functionality has worked extremely easily.
Thats what is in question and at risk here - and that set of functionality was (if you excuse the phrase) idiot proof.
Not that AP2 is difficult from a phone, be it starting / adding speakers.
Additionally the ability to multi-room other sources (analog, DLNA, TV, audio from Youtube videos, etc etc) - these will be gone natively from a B&O architecture, and we'll have to use a range of 3rd party apps to replicate.
I appreciate that AP'ing to multiple rooms from a Mac works well, and has done for a while (I used to do it a lot), but its convenient only in some circumstances, and doesnt cover the situations described above.
But hey, go and get a equipment that hosts another native multi-room protocol (Songcast, BlueOS, Roon etc etc) and the risk becomes similar - that they abandon the space and ask everyone to use AP or CC.
Fansastic wrote:
matador43 wrote:
Thank to you both Fansastic and Sandy for your replies and clarifications on what I missed.
I also understand your points and agree with them.
One question thought, I understood that a BR1 can start the radio. but can you navigate a local library or even a provider library with from the remote? Or do you start the source and then need to go to an app to choose say this album?
A sort of the latter, you can skip to next songs with both touchpad or remote but for full control you need the app. Therefore in my case I use my Moment for playing songs/playlists amd then tap to join every other divece in the house. If not in the room with Moment I use the app for controling the Multiroom session. Hence why I really want the B&O app to thrive 🙂
