What are you looking for in the picture to se if it’s RGB or CVBS that’s on ?
If you go into the service menu, Monitor, Picture adjustment, Colour adjust, it (presumably) tells you what it is using (CVBS 043), I can also flip to the other setting RGB 064 which does change the picture.If you go into e.g. the program guide on the STB (loads of text - thanks for that tip) and look closely, under CVBS all the text looks like it has ghosting - if you flip to RGB this goes away.
This is where it gets slightly embarassing 😳 I had assumed that since every time I went into this option it showed CVBS that is what the picture I was normally getting was. However while writing this and looking closely at the set what seems to happen is that when you go into this option the picture is indeed CVBS, however when I come back out if resorts to RGB so I may be getting RGB all the time.
However all is not well so please bear with me. The reason I ended up here is because I all to often find the picture unwatchable so I ended up trying to change service menu settings (yes, I know the risks and have tried to minimise this by making a note of the original settings, which is fine so long as I can see a picture to restore them to those values) and RGB was one I was hoping would fix my problem.
The problem I'm trying to fix is again particularly noticable with text, but also other things (most noticibly with sharp edges) but only on some programs. Those of you in the UK will no doubt have seen the new weather that one of the channels is doing where they fly over a map of the country which has place names on it - depending on how fast they move you sometimes can barely read the place names because they are so jumpy, and yet when the slow down slightly it is really clear and smooth.I have tried the Movie mode, however this has as many problems as it tries to fix in my mind and I'm sure that without this the text etc. shouldn't be as jumpy as it is. The problem is only ever with things moving left - right or right to left - up and down is fine (you can see this from credits at the end of programs, those going right to left jump between being legible and not - while those going bottom to top are always fine. Sometimes the right to left credits are unreadable and after 5 seconds suddenly become smooth and then go back to jumpy again. If it was just credits I could live with it, but in some programs it is very noticable (e.g. The Apprentice) - it is almost like 10fps instead of 25fps when stuff is moving fast across the screen. Could this be the problem, the set can't cope with so much motion??! Surely not.
I normally only watch through the STB / Tivo, but it appears that the problem exists on TV from the inbuilt tuner (ok, it appears RGB was a red herring, I wish this had occurred to me before). It is also harder to work out what is going on from here as it's obviously only live so you have to wait for a particular program to have the problem.
Maybe this has been fixed in a later s/w version? Mine has EEPROM ver 043
I do hope someone can shed some light on this problem otherwise this set has been a very expensive mistake which has to go...
Many apologies for the RGB confusion and thanks so far...
Jeddy
