Login to view imageMain fuse has blown;
I am curios to know if this is a standard update of the main print..
How right you are Martin!
I did short test with a new fuse on the cassette deck.
Standby light came on , but smoke as well! I suspect that it came from the big capacitor in the power supply.
I disconnected at once.
Question : do I change the big capacitor for an identical one?
Can any other component have been affected?
TIA
Hugo
