Sorry if this is a simple one but I can't find the answer! I used to have 5 Beocom 6000 handsets registered to the same base. Due to two of the handsets going faulty in the last few years, I now have only three working handsets left. Only trouble is the faulty handsets are still showing as associated with the base. Whereas I know how to remove a working handset, I do not know how to remove the references to the old handsets now that they are not working anymore. Any ideas gratefully received. By the way, I do not mind doing a factory reset on the entire setup if this is possible so I can start again.
Thanks in advance,
Steve
