Removed Audiomaster from NL/ML converter. Need assistance with settings.
Hiort wrote:
w5bno123 wrote:
Hi
The NL/ML convertor still needs to be the video master and the sources listed on the BeoVision 11 need to be set as video sources and not audio commands.
I´ve set the NL/ML as V.Master. In the view "Sources visible on ML" the ML Audios Sources are greayed out, and the video sources are not. Is that what you mean?
thats correct in this setting. Be sure you have UN-checked the RADIO box in "Experience mapped to NL".
And assign the right source to the right IR command in the tab: "IR Mapping"
No luck🙁
Here are my settings.
Nothing happens at the BL3500. Not even accessing whatever is played on the masterlink.
Did you asign also in your TV menu (not the converter), check it!
EDIT: check on menu > radio must be DTV2
and the radio text must be disappeared within the ML part
Put power off converter, wait a few moments and put it back in. Let it restart...
Above pics are the same as mine, it works over here: (V1, BV3, ML/NL converter, Passive and BL2000) in a ML link
Hiort, do you have something connected to the USB of the NL/ML converter (the 000.000.000@.......... IP address in your setup).
Maybe you should do a reset of the NL/ML converter. Something is going wrong there!
Don't let him loose all settings, just power Off & On will be enough!
I will do a reset. Think BC2 settings are still there.
I have powered off and then on again.
No change.
I have changed the "000000 .." to empty since they where still there after the reset.
This is really difficult. 🙁
Is there a more detailed manual for the converter, since I do not understand all the settings?
The answer was given earlier but seems to have been overlooked
MasterLink only works when you have a "Current Master" on the ML to supply the voltage/power for ML to function, that used to be your BC2 but now that's gone you are missing that for ML to work
Only audio systems with ML or Video products with ML can act as the Current Master, the only exception is the old BeoLink converter AUX/ML that can also do the job, but without it your masterlink system will not work
Sorry for the bad news, hope this helps to get the problem sorted out for you
So the power on or off had no change to the good. Hior, don't give up hope!
Did you asign also in your TV menu (not the converter), as I asked... check it!
check on TV menu > radio must be DTV2
- Can you start the radio on your TV with the command DTV2? Do you hear it playing?
- Have you been trying on the BL2000 or only on BL3500?
Set-up button in small hole aside the light; try a factory reset and reprogramme the BLC
