remote cable
could someone please tell me what the cable is called that plugs in to my beovision 5 with a little eye thing at the other end taped to my sky box, so that I can use the beo4 to control sky box.
Its just when the sky man pulled it of the old box he broke a wire . I have tried to solder it but have given up.
also do you have to go to b & o to get one or can you get a universal one from maplin
cheers colin
I think it's simply called an IR remote sensor cable - as you called it in your post. I have one somewhere doing nothing.
Chris.
Hi Chris
thanks for that
did you want to sell it to me if so let me know how much. I can pay via paypal
cheers colin
Did you resolder the broken wire itself, or did you use a new connector/jacket?
Mind the polarity from the ir-eye. You can't just resolder the wire without checking the polarity.
If you use a new connector, then the chassis is ground (-) and the little top is the positive lead (+). -> STB/DTV
If you re using a 3,5mm stereo jacket, then the middle ring is the positive lead for STB/VAUX.
So if your soldering doesnt work, try to resolder the wire and switch both leads. It will not damage your BV5 by switching the leads.
It works or it works not, its that simple.
You can buy a standard ir cable to the job. I got one from ebay for appr. 8$ incl. shipping.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
