OK
Basically I am currently looking at Jantzen MKT metalized polyester film caps. I don`t know how well regarded these are but they come in 2 diff. voltage ratings and are cheap.
I think to replace the original 63v caps with 160Vdc caps..so 3.3 and 10uf @160 Vdc
and the 100v rated caps with 250 Vdc caps..so 6.8 15 and 33uf @250 Vdc
Do the voltage values sound ok. If there is a better known brand of reasonable quality budget caps out there what are they and where can I get them.
I`m currently using hificollective.co.uk
Thanks again
