Red Beocom 4!
Yes I must admit that does look very nice in red. Perhaps B&O should take note of that, there may be a market for it. I am trying to imagine my BeoCom 2 in red although I wouldn't have the nerve to try spraying it!
My dealer told me the BeoCom 6000 will be available in white and red very soon. Didn't mention anything about the BeoCom 4 though.
I have seen a metalic lime green BeoCom 2. It looked great!
By tooth i mean did you sand or prime the surface before you painted it? If you didn't get a tooth for the paint to cling to, the coat may end up flaking off!
Well tooth really is a first to me! Yes I applied a transparent undercoat.
A red Beocom 2 would be hawt!
If B&O released a red Beocom 2 i'd get one in a heartbeat
Hey up Henry!
New buisness venture in the offing?
For David's tooth, we would more likely say key. Light abrasion before painting provides a key for the paint to adhere to.
Andy T.
