Recording via USB BeoVision Avant
Hi, I have a BV Avant 55" and I checked out the recording feature via USB. I connected my Hard Drive to it and I got a message: use this HDD for records. I confirm and it is formatted in an unknown file system that is illegible to any computer. I try to record and it works but how can I take recorded files out of that HDD?
Thank you all in advantage
Hi
I think they are trying to adhere to copyright laws. So it will record and let you play on the Avant but it will block you from using it on a computer so that you can't copy or share it.
maybe there is a way to by-pass this... I hope somebody knows more about this Avant's feature..
thank you for your reply btw.
Good evening,
You may have more luck looking in "underground" forums specialized in cracking stuff than here. B&O must certainly use an off the shelf solution for recording on the hard disk. I suspect the format used is an encrypted Linux/Unix file system.
Good luck,
Jean
