Recommendation for a new router
I am looking for a new router with wifi extenders (as my house has solid brick walls and wifi does not seem to travel that far through the house.
My old one has died plus the extenders all seemed to set up different zones, they were all set up to the same network passwords etc but my Beolit 12 did not seamlessly move between them and I had to use the app to join a new netwrok when I move from one area to another.
Does anyone have any recommendations?
Toby
I also have a house with very difficult wifi issues. I have use an Apple AirPort Extreme, with power line Ethernet, to the most difficult areas. From those distant (wired) points it is possible to have additional wifi. It was the best I could do without investing $2000-3000 in wiring. It works.
As far as I know the issue with WIFI is that it is not possible to "change networks", even extended ones without a proper reconnect.
For the ultimate we install a wireless mesh system in large properties. Can be expensive.
Recently on a large install (Playmakers all hard wired) we installed this router non WiFi version:
link
With this single Access point:
link
Great range and worked a treat :)
With regards BeoLit 12 I'll have a go at working out something.
We use a lot of the Unifi series also. Normally the Unifi Pro
Great kit sshh don't tell everyone ;)!!!!!
I am not a wifi fan - anything that bathes people in microwaves is inherently dangerous.......
In your case the simplest option could be buy a Hilti masonry SDS drill and some long masonry auger bits ( say 12-24 inch ) and drill through walls and run some 1 GB Cat 6A cabling and buy a 1 GB 5 port local ethernet switch and run a wired  wired connection to either another wifi unit/repeater, or just plug into the cable directly.
Simple = robust.
How large is your coverage area? If AirPort Extreme with extenders won't work, it may be simpler to invest in a business grade solution such as Cisco 541N router with built in wifi. There are also other options with business grade access points which should provide good coverage for about 2500-3000 square feet.
Apple are shortly bringing out a new more powerful router that's meant to be good - I use a couple of  airport express to extend my network wirelessly as the building is around 250 years old with thick walls. It works really well with no drop out when moving from one zone to another and streaming music from my iPhone.
Thanks for all the advice, will look at all the suggestions and work out which one suits my needs best.
I plan to wire the house with cat7 cables which will over the ML, PL, and ethernet, and then have wifi for my ipad and the beolit.
Toby
