recharge problem of beocom 4
Dear all,
I have bought beocom 4 for a few months only. Soon after purchase, I discover there is a connection problem between beocom 4 and the base charger. Even i have put it onto the charger, the metal contact is not functional, the recharge does not start everytime.
May i ask is it a common problem for all of you? and is it possible to solve it forever?!
There are some problems with the Beocom 4...
First: The metal connection under the Beocom can get broken very fast, so you can change that at you dealer....
Second: There seems to be a sw problem with the Beocoms... although they are fully charged the sw gives a signal that they are not so the beocom turns off. So the thing you can do is go to you dealer and give it a upgrade.... and it all will be over........ 😂😂😂
