Reccomend a DAC for BeoLab 3's
Hi Guys,
Can anyone suggest a good DAC to use from my PC Via USB to connect to a pair of BeoLab 3's.
TC
Depends on how much you want to invest, and whether it should be a 'USB-DAC only'?
I was think more something like this?
Xonar Essence One
http://www.asus.com/Sound_Cards_and_DigitaltoAnalog_Converters/Xonar_Essence_One/
As I want volume control on the desk..
But not sure it's suitable?
TC
sorry, the link should have been,
having problems with the forum format
Ok, if you want to spend the money - I wouldn't!, but it is your choice.
I'm not that convinced of the upsampling technology of the Asus.
Personally since a couple of years I use the Nuforce u1 with a set of active speakers on my desktop MacMini.
If I should buy a new one, I'd probably go for the newer u2 (or the u3) or the Audioengine D1.
Much more important with your BL3's than an 'over-expensive' DAC is, what you intent to play back (lossy or losless files in 'red book' or 'high res' resolution),
and how you will play them (which player/which audio driver...).
I would say the 3, I mentioned above, are pretty good - at least for a start.
