Alex wrote:
Having broken down a lot of surround sound mixes, you'd be surprised what often gets sent to the rear speakers! 70% of the time there isn't really much going on below 150 Hz (ie, not much bass at all), but occasionally you get really full-range content!
House of Flying Daggers springs to mind. When you play the bean-throwing scene on a 5.0 system with full range speakers all around the effect is spectacular. Using a subwoofer is cheating!
The only potential issue with BeoLab 9s as rear speakers is whether they're high enough to get over the top of the sofa. Ideally, the tweeters should be slightly higher than ear-height, which you can see is difficult to do with BeoLab 9s! 😂
Very much agreed. Dolby specs actually call for five full range speakers all around in a surround sound setup, plus an separate LFE effects channel; using smaller rear surrounds, usually crossing over at 80hz to the sub to allow the rear channels lower bass to be reproduced along with the LFE is 'permissible' - BUT as Alex points out, full range speakers all around certainly have their benefits and is the setup of choice if finances and space permits. Certainly I prefer to run all my speakers set as large in a surround sound setup - unless you cross over at 80hz or lower (which means a decent size speaker anyway), bass can be directional, and stereo bass in the rears is preferable to 'mono' bass coming from up front from a subwoofer doing double duty for LFE and bass from the rear surrounds. I'd also opinion that by removing bass management with crossovers etc re setting all speakers to large, the overall sound detail and transient response improves as well - perhaps because of phase or other issues involved in the crossover process.
I have heard a movie demo of Beolab 5's as fronts, 9's as surrounds, and 3's as back surrounds in a 7.1 setup (really 7.2 using the speakers in the lab 5's for the LFE, and the sound was far and away the best movie sound I've ever heard - including much vaunted specialist movie surround sound setups such as M&K THX systems etc.
So, very much with Alex on this one
Best regards
John... 🙂
