I recently bought some lovely used Beolab 8000's, and the owner provided me with a tangle of powerlink cables to go with them. When I got home however, I found the cables had been cut in half for some reason...
These are about 10m long, so worth saving if possible. I think they are MK3's as there is a yellow and a blue cable, then a brown and green cable each wrapped in wire, which I presume is shielding? Is there an 'official' solution for joining these together - bearing in mind I don't have soldering equipment or abilities, or can anyone recommend a workable, inexpensive solution for this problem?
Incidentally, I have a couple of UK 'BT78A'-style telephone junction boxes, used for joining telephone cables; I wondered if I could use these, but I don't know anything about these boxes re. voltages etc. Also, would I just twist together the shielding wires from the brown & green wires and join these together, or must they be joined separately?
I'm happy to try to salvage these if possible - but please just tell me of I should just throw them in the bin and buy some new ones!
Kind Regards to All.
