Re-covering beolab 6000 grills
No problem, will upload the finished result.
It's probably too late, but if you go to the store and buy some black stockings (pantyhose) it is literally the exact same material as the 6000 frets, really easy to work with, and conveniently already sized for the 6000s. AND people have two legs so you only need one box. Stick them on with hot glue on the back and you are good to go!
And you can select from a number of exciting patterns! Just make sure the seams are straight 😁
(Great idea, BTW.)
But he wants white!
Leslie wrote:
But he wants white!
okay, so get white pantyhose then. Do you remember "Schwanensee"?  Those ballet dancer pantyhose are white ;)
Sounds good, the cheapest and quickest way.
