Anyone tried th RE-BL with Beovision 7-40? Does it work well? What about the PS-button? And how do you control the PS3 with Beo4 trough BV 7-40? Are the PUC-codes in the latest software? And two more things, can the DVB-HD be installed in a MK3? And are the menus on mk3 black with the latest software?
RE-BL, Beovision 7-40 and ps3
Can someone help me with this?
PS3 will work with BV7 MK11 and MK111
Get a proper TV Tech` to instal the PS3 PUC code for operation with Beo4/5
MK11 can be difficult as it uses DVI in.This means you need HDMI to DVI cable with
seperate component audio cables via the AV4 input.
Use PC command and set the input to DVI.
Set PS3 output resolution to 720p or 1080i
You may need a revised scaler board and firmware (Proper TV Tech` again)
Flash software to version 7.91
MK111 is more easy.Plug in to HDMI A.B.C. or D if it isn`t using D for Blue Ray
Get software level 7.05
Set PS3 resolution to 1080P
