Radio reception on B&O 7700
I have tried connecting a wire to the external antenna jack but with no effect on reception,any help would be very appreciated
To see if it is working, try plugging a TV aerial in it - there should be a co-axial socket.
I'll have to go buy an antenna and see if that works. I did try clipping a wire with an aligator clip on the end of it to the center pin but nothing changed
They normally work if you put a screwdriver in the hole actually!
