I am considering the BS Core, but still have some old IR products. Does anybody in the forum know the following:
1) Is it possible to control the BS Core with bluetooth (e.g Beoremote One) and IR (Beo4) at the same time?
2) If you are using the core with Beo4 (IR) is it then a way to select the optical input or does the optical input have autosensing and turn on the Core when it receives a signal on the optical input?
