I plan to get 2 beolit 15 soon to get them into stereo mode. I will use these 2 for my computer speakers and would like to know if the speaker remembers the stereo pairing after it turns off and aren't moved. It would be an annoyance if it doesn't. Also does the device always stay on if I have them plugged into the power outlet all the time? Thanks
Question about Beolit 15 stereo pairing
I would recommend a pair of BL4000 for that use. And then you can buy a extra portable.
I think a pair of S3 would be much better suited.
They will always be "on" and they retail for quiet a bit less than a BeoLit 15
FYI in an interview a B&O spokesperson said that the stereo pairing does not give proper stereo.
Thank you for the clarification. This is my first time owning a B&O device so still looking forward to it and at the price I got them for. Very helpful community here too
Is that just the S3s ?FYI in an interview a B&O spokesperson said that the stereo pairing does not give proper stereo.
How about a pair of BL4s for pc use?I plan to get 2 beolit 15 soon to get them into stereo mode. I will use these 2 for my computer speakers and would like to know if the speaker remembers the stereo pairing after it turns off and aren't moved. It would be an annoyance if it doesn't. Also does the device always stay on if I have them plugged into the power outlet all the time? Thanks
Duels:I was said when talking about the A1. It is done with the Beoplay app, so I am guessing it goes for the whole range...?The BL4 is still a bit expensive for the sound they make?BL4000 is a proper speaker and the best sound you can get next to your computer screen.in my opinion at least.
Duels: I was said when talking about the A1. It is done with the Beoplay app, so I am guessing it goes for the whole range...? That's useful to know.
