Putting BeoCenter on timer in link room
Hello,
I am looking to install my BeoCenter 2300 (type 2611) into the bedroom, masterlinked (using the Beolink converter) to my main system setup (Avant CTV+BeoSound 9000). So far so good.
I also wish to use my BC2300 as an alarm clock to wake me up with music for a perfect day ;-)
As I know that BC2300 doesn't have any timer function, could I instruct the timer function of the Avant (master) to wake up the BC2300 at a specific time? How could it work?
Thank you. /P
Not sure a Video Master could trigger an Audio Slave to perform a 'wake up call' - but if it can be done, i'm sure someone on here knows!!
Anybody?!
Lee
Thanks Lee for bumping my post. ;-)
I have checked all the options on the Avant but no chance: all timer options accessible are for the sources hooked directly to the video master. No timer options for audio/video slave in link room.
I have also checked with a BV6 in a link room. The timer play for this TV is adjustable directly on the set.
So I guess I have to find a BeoSound that has a timer option, unless somebody has a good tip.
Cheers.
Thanks AT... but I heard that timer programming with BeoLink5000/7000 would work only if you have a two-way BeoCenter 2300... From the type number of my set, I think it is only one-way.
I hope to be wrong again! ;-)
If you can confirm...
Hi!
You can easely determin if your BC2300 is two-way or not. If it has an IR-eye on the bottom left side (below the glass door) it is an two-way unit.
Cheers
Foxtrott
You did say that you have a BeoSound 9000 in the main room?  Have you set it's timer and tried that yet?
I don't really hold out much hope for you, as the 2300 and 4000/Overture didn't have the capability of becoming 'link' systems.  But I will be interested to seew how this plays out.
Russ
My BeoCenter 2300 is definitely not 2-way.
Concerning the BeoSound 9000, its timer is controlled using the master, i.e. the Avant. Turning on the timer on BeoSound says: TV Operated. Turning on the timer for the radio on the Avant turns on the BeoSound.
My last hope is that I can program timer play using BeoLink 5000/7000 even if the BeoCenter is not 2-way. However, I don't a BL 5000/7000... yet.
Did somebody already tried it or knows if this would work?
If the 2300 is not two way, the 5000 cannot program it. Sorry!
