PUC (Peripheral Unit Controller) List Updated
I want to draw members attention to the fact that the PUC Library List has been updated
Thanks for the great info!  It lists a GDishDVR with two versions, 1.00a and 1.10a. Also lists Sony BDP-S300 with two versions, again 1.00a and 1.10a. Any idea what the differences are between the versions and also is there any way to tell which version we have on our BV7?
The changes are small as follows and you should use the latest version:-
GDishDVR
The changes relate to the timeout period when using PLAY (GO) and adding 0 (GO) macro command.
Sony BDP-S300
The changes relate to adding 9 (GO) macro command plus adding timeouts which were previously zero.
Thanks!
@ Keith,
do you have any idea, if and when the HUMAX icord HD+(plus) ( I know, the HUMAX icord HD is already included ) is going to be integrated?
regards
Nobsi
The HUMAX icord HD+ has been available in the PUC library for sometime, in fact there has been 3 revisions of it as you will see
Thanks for your quick response. Unfortunately, the Humax icord HD is not the same as the Humax icord HD+. In the list I only find 4 versions for the Humax icord HD ( Versions 01.00a to Version 01.30a ). the Humax icord HD version 01.30a does not work with a Humax icord HD+.
regards
Nobsi
Nobsi,
Sorry about that, I missed the importance of the + sign, well I made some enquires and apparently there is going to be a Humax icord HD+ PUC update in the very near future, possible later this month..
Thank you for your quick reply.
regards
Nobsi
I notice the Ipod dock is in there but no mention of the Microsoft Zune. Perhaps the XBox has the same codes?
David
