Does anyone know if the TVIX codes that are in the PUC tables also support the newer Tvix N1?
| TViX | HOME MEDIA | M6500A | V01.00a |
| TViX | STB | M6500A | V01.00a |
| TViX | STB | M6500A | V01.10a |
Hi
Before I purchased the Tvix 6600 I asked the Tvix dealer if the 6500 remote was the same as 6600 remote, since B&O only have PUC codes for 6500. And it was.
Maybe you could do the same, i.e. ask if a 6500 remote can be used for N1.
I looked at the codes in the PUC for all three TViX units and they all use 32 bit NEC codes.
I checked the binary of a couple of the commands and they were 100% the same, so I am guessing that the TViX N1 will be the same.
Thanks Keith!
I will have a go at the TViX N1 and will confirm if it works or not.
/C
Hi Keith
I Have a BV 7-32 type 9311 and i dont think it ever has been updated software .(nearest B&O dealer is 400 km away). I recently bought Beo 5 and the first step in setting it up (try and failed)but it is working .
I also has a decoder Canal Digital (Sagem PVR 102 CT) and this one is understandable not in the list of decoders. Can i use another one (just to change channel at least)
I ment to buy a new BV 10-46 this autum and the Decoder will hopefully be in it`s list. (sold my BV 5 a year ago) and take the BV 7-32 back in the bedroom. But if i could get it working until the BV 10 is in house it would be great.
Is it any other possibility to upgrade SW since the nearest delear (and his laptop) is so far away.
I also have BC 2 DVD(SW 2.0) -BL5(front)-BL 8000(rear)-BL 4000(center on 7-32) 3-Beo 4 -Beo 5 and two BL2000 in linksystem.
Frank
/C
Hi Hiort,
I'm looking into buying a TViXN1 as well. Can you (or anyone) confirm yet that it works with the STB/PU-codes for the 6500A and 6600?
Kind regards,
Menno
Hi Hiort,
Kind regards,
Menno
Yep, TVIX N1 is now in the PUC table and works perfectly.
It now has its own codes so you can ask your dealer to look for the TVIX N1 codes.
It´s a nice media player. Enjoy.
Thanks. Sadly I can't use the PUC, but only the STB-C chip. The TVIX 6500A is on the last update of the chip, so I was hoping the same code would work for the N1
BTW, does the N1 work flawlessly? I read quite some negative reviews; it seems to crash quite often?
Kind regards,
Menno
I think that the codes are very much the same as for the 6500. Main commands that you use is just navigating up, down etc etc.
The TVIX never crashed for me. I really like it. Handles all formats I feed it with.
Hi
I have a Tvix 6600, and I just got the PUC for 6600 installed, and this work better than the 6500 PUC codes, and I guess that the N1 use the same as 6600.
I.e. with PUC for 6500 it was not possible to change language in a movie, that works now. And the navigation (i.e. back) works more logically with the 6600 PUC.
A shame that only the dealer can install PUC codes.
