Puc codes for samsung stopped working
kimhav wrote:
How do you check the BV10 software version
Press menu (twice if you have DVB HD module) to go into the TV menu. Highlight the options tab then press red + go. That takes you into the customer service menu. In here you can see which software build is currently in your TV. The latest software for BeoVision 10 and BeoVision8 40 is build 153. Amongst other things this cures the problem of the PUC loosing commands.
Opman
Samsung Blue-Ray V02.00a
Beo4               Orginal
Go                   Enter
Stop                Stop
Exit                  Return
Up                    Up
Down               Down
Left                  Left
Right                Right
Red                  Popup menu
Green              Mode
Yellow              Slow forw
Blue                  Slow Back
Menu/Go+
1                   Menu
2                   Disc menu
3                   Info
4                   Audio
5                   Subtitle
6                   A
7                   B
8                   C
9                   D
Notice that Pause command doesn´t exist. Stupid in my opinion
Big thanks for the answers; very helpful!
Thank you for the nice overview of the codes!
Is there also a way to eject the disc with the Beo-remote?
Unfortunately the Eject command is not available in the generic Samsung Blu-Ray file!
What setup are you using? If your TV supports PUC flashing, I recommend that you check if there exists a specific PUC for your Samsung player and contact your Dealer for an update.
Why would you need this? If you want to take the cd/bluray out and put it back in the box you will need to go to the player anyway...
An eject button would need to be an eject-back in the box-in the sideboard-button ;-)
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
My whole Blu ray player is hidden behind a extra front wall where also my tv is mounted.
Just the slot-in (Samsung BD-D7500) can be reached for putting the disc in/out. Now when I want to eject the disc I have to take the player from behind the wall to push the eject-button, which is located in the middle of the player and put it back behind the wall again.
A bit silly....
Why don't you put/wall-mout the original remote there as well?
It should still work! It is not an either-or but the two remotes (beo 4 and orignal one) work side by side.
Push the orignal remotes eject button and that's it....
Ralf
I now use the specific codes for bd-c7500 and everything works perfectly. Bd player hangs at the back of the bv10 using stb brackets.
If I remember correctly I tried codes for another samsung and could then eject disc but many other commands didn't work.
Codes for samsung bdp4600 has the eject function but is missing a lot more.
