Hi folks,
I am using a FLIRC USB IR receiver connected to my fire TV stick to receive IR commands sent from the beocenter 6 23's PUC IR blaster. I am using the PACE SKY+ STB PUC option on the TV. All works except that there is a delay of a few seconds before the TV blasts the GO button command from the beo4. This makes navigating the fire TV quite painful. Is this normal? Its nothing to do with the FLIRC or the fireTV stick as using my phone's camera I can see the IR blaster lighting up a few seconds after the OK press on the beo4 - its like there is a processing delay going on in the TV. The beo4 is firing the GO command as soon as it's pressed. All other IR commands get blasted from the TV's instantly too. Does anyone have ideas how I can fix this?
Many thanks.
