To all B & O users read below.
I am not impressed with B & O.n update for all Beovision 7 owners who could never get digital audio feeds working with STB's, PC's, Apple TV's, CD players and other sources outputting digital audio. Quite simply ... The Beovision 7 DOES NOT currently support digital 2-channel PCM.
If the signal is Dolby Digital 5.1 you will get sound, but music, Cable and Satellite STB audio (non-HD) and pretty much everything else that isn't full 5.1 Dolby is unable to be processed by the on-board Digital Surround Sound Module. Dolby's own website states 'all Dolby Digital decoder units also incorporate a digitally implemented Dolby Surround Pro Logic decoder'. 2-channel PCM would normally be handled by the Pro Logic decoder and give you either standard stereo (music CD's) or if there is additional surround information encoded on the 2-channels, Pro Logic Surround sound (STB's etc).
You decide if B&O have met the terms of their licensing agreement with Dolby, by only partially implementing what is a clearly defined standard, but branding their product as being Dolby Digital compliant nevertheless. For those interested, try reading this document from www.dolby.com: http://www.dolby.com/assets/pdf/tech_library/42_DDFAQ.pdf
I was advised that the problem is not able to be corrected via a software upgrade, and there are no plans in place to modify the current chassis to address this problem. The problem does not affect the newer chassis as used in the Beosystem 3 or the Beovision 8. A new generation Beovision 7 will be released at some point which will utilise this new chassis, but there is no release date as yet. So for all those who purchased a Beovision 7 and were told that their new TV set was HD-Ready (HD refers to audio not just video) will be disappointed to find out (rather belatedly) that their expensive new equipment cannot accept digital stereo feeds and connecting their digital sources (CD players, STB's etc) may be difficult or even impossible.
I would welcome a moderator, or other official B&O source to comment on this issue and provide an update to the many unhappy and confused Beovision 7 owners who have been struggling with this issue since the 'HD-Ready'/'Dolby Digital' Beovision 7 was first released.Carl
