Hi all,
I plan to install a projector and 2 pcs. 2nd hand Beolab 5’s in a bar in my house.
An Apple TV 4K will be connected to the projector
I am using NL in all other rooms in my house (BL18, BL50, Harmony, M5’s, 3 pcs. Halo, etc.) and I want to ensure I can also use NL in the bar.
I assume I need to connect a core to the BL5?
For audio, do you recommend I connect the projector audio directly to the core or directly to the core (maybe by optical) ?
What is your recommended setup?
